SOLD Atlanta, GA: 2005 AT Horizon
Status
Not open for further replies.
See pictures in link. $8K.
Any additional info on the trailer, any damage. Build sheet, what all is included?
I tried clicking the link but it told me it needed access to all of my stuff so I didn’t go any farther.
Technical difficulty on my side. Cool little trailer
No damage. Good condition with some wear. Pictures are very recent and accurately represent the condition.
Additional info.
- New 12x33" 50R15 Cooper Evolution M&S tires with chrome wheels
- New wheel bearings, packing, and grease
- Heavy duty 14 gauge steel laser cut chassis, powder coated corrosion protection
- Side protection bars
- 2" receiver type tongue and 2" rear accessory/recovery receiver for accessories
- Lock and Roll multi-axis coupler for articulated travel on and off pavement
- Stainless steel hinges and latches throughout
- Textured black chassis and suspension, high reflective white body components
- Electric break-away brakes
- Gas strut assisted cargo lid that can be opened with rooftop tent up or down
- onboard 2.5 gallon/11 LB propane tank
- 1 additional onboard 2.5 gallon/11 LB propane tank
- onboard kitchen with mounted two burner Partner Steel stove and flip down removable cutting board (passenger side)
- 1 22" Partner Steel Hard-Anodized Aluminum Griddle
- LED lit kitchen
- onboard storage box (driver's side)
- nose box for storage and battery
- onboard 1500W inverter and 12-volt outlet
- onboard dual 225AH 6V VMTanks deep cycle AGM batteries
- onboard NOCO GENIUS G26000 12V/24V 26 Amp Pro-Series Battery Charger and Maintainer
- onboard NOCO GCP1 15A AC Port Plug, 125V Power Inlet Socket, and Waterproof Electrical Outlet Receptacle Box with 16 Inch Integrated Outdoor Extension Cord
- onboard Renogy Rover 20A 12V/24V Auto DC Input MPPT Solar Charge Controller Parameter Adjustable LCD Display Solar Panel Regulator fit for Gel Sealed Flooded and Lithium Battery, Rover 20A
- 400W Portable Mohoo Solar Panels 3x100 watts each
- 1 GoPower MC4 Connector Port
- External 12V port with voltmeter
- onboard 19 gallon BPA free food grade plastic water tank with a battery powered pump/faucet
- Mr. Heater BaseCamp B.O.S.S XCW20 Battery Operated Shower System
- onboard 10 gallon (2 5-gallon) gas cans and mounts protected by an under-side skid plate
- onboard Maggiolina Airland crank up roof top tent (includes a spare crank) with hard shell and 5" memory foam mattress and interior light
- 1 MAGGIOLINA / AIRTOP changing room
- Roof mounts on top of roof top tent for solar panels
- onboard aluminum ladder
- onboard 6x6 Fiamma roll out awning self contained in an aluminum snap shut case
- rear flip down work space platform door
- rear slide out refrigerator storage slider with 12-volt electrical hookup
- interior cargo tie down points
- interior floor rubber mat
- Valterra 020106 RV Stabilizer
- 1 MaxxHaul 70422 48" x 21" Hitch Mount Compact Aluminum Cargo Carrier - 500-lb Load Capacity
- 1 WILCO Offroad Hitchswing (adds a secondary 2” receiver hitch mated to a swinging arm)
Overall Length: 124″
Overall Width: 68
Main Cargo Box: 40″W x 30″H x 54″L
Side Box: 14″W x 14″H x 54″L
Nose Box: (32″ W + 12″W) x 20.5″ H x 21.375″L
Cubic Capacity: 54 Cubic Feet
Base Trailer Weight: 1100 lbs.
Payload: 1600 lbs.*
Ground Clearance: 24″
Box Material: 14 Gauge Steel
Chassis Material: 2″ x 3″ x .120″ steel tube
Bumper material: 2″ x 5″ x .187″ steel tube
Coating: Zinc primer and powder coating
Ad states Jeep lug pattern, pics show these to be 6-lugs (prob. Toyota), FYI.
GLWS
GLWS
I caught that as well and will correct. The picture is right - 6 lug. The wheels on the trailer are not stock but was modified by previous owner. Your comment has led me to research the wheels so that I can have the brand, lug pattern, and offset. Thanks!
Status
