ArticBlasting
An appropriate detergent and steam cleaning would accomplish the same task prior to an oil/lanolin undercoating and only cost a few hundred $.
But as stated, if you don’t mind parting with your cash and this rig lives in a dry environment then Giddyup go👍
no, it won't. I have a capable high pressure propane burner that creates 270 degree water at 1,300 psi. it still wouldn't touch what the dry ice blasting did to my frame.
With appropriate detergents it will.
However, it sounds like you want like new underneath vs cleaning prior to an oil/lanolin based corrosion inhibiting compound.
I guess you are not applying that type of corrosion prevention?
Where do you live , south or north?
If I’m spending money to dry ice a car, I’m not dumb enough to put it through Chicago winters after that. To each their own.
