ARB Question
Richmond, VA
a freind is selling his cruiser (very overpriced). The Fj-40 is mostly stock, but with an ARB in the rear. So this is my question. Can/Should i buy it (the ARB) from him? How much? Can i install myself? Thanks for awnserING THIS DUMN QUESTION
If you swap the whole third, no problem....
Less than 800.00. If you can get the comp. too, you will be doing really well.
-Steve
can you explain "swaping the third"? i know you mean the 3rd member, but issent that attached to the housing?
Jack up and support the rear axle on jackstands, remove the wheels, drain the gear oil, remove the rear cover, remove the cross shaft retaining pin and cross shaft, block and spacer, bump the axle shaft inward to release the pressure on the c-clips, remove the c-clips that retain the axles and slid the axles out six to eight inches if not all the way, unbolt the driveshaft, unbolt the third member/differential to the axle housing, seperate from the axle.
Good luck!
-Steve
Very clearly coverd in a factory service manual...
Hopefully your ' friend ' still has the instructions for r&r of the little ARB goodies to get the axles out...otherwise contact cruisinGA, he just did this! ;)
-Steve
ok, thanks, so you all agree 800 is a good deal?
