ARB locker install question
Raleigh, NC
I am trying to install a new air locker in my FJ40. I am only a "shadetree" mechanic. The carrier bearing portion of the install is looking questionable for me. Does anyone have a good method of removing the carrier bearings without damaging them? Is it possible to install the carrier bearings without a press......would a rubber mallet work? I might be getting in over my head with this one......
I have pulled the carriers bearings with a puller without screwing them up. If you look at the carrier carefully, there are little slots cast into it behind the inner race so that you can get the jaws of a puller behind it.
OTOH, you could use new bearings. They aren't that expensive. All you need to do is set the backlash and preload. There is a technical write up in the technical links with pictures that covers this:
http://members.cox.net/cglabe1/Diff/diff.html
