I have a ARB Compressor and locker in the rear. When i press the compressor switch, it turns on and after about 15 seconds of pumping stops, which i normal. Then immediately when i flip the rear locker switch, the pump starts to repump and does not stop because there is an obviouse air leak noise coming from the pump. If you look at the pic it is coming from one of the things that are mounted next to the air line. The air is leaking out of that little hole. Now here is the wierd part, when you remove or unplug that part, the leaking stops, but the locker still does not work. What is the problem guys.
