Sorry guys I have been snowed in with my two boys so I havent had too much time to do anything but entertain them. So yes
@inkpot we do drop them but not usually the same amount as the lift itself. Some is better than none. I just dropped both mine to go from "WHOA WHOA WHOA" as the boys said the first corner I took them around, to just a lifted bus feel. I have to drive very defensively so as not to put myself in a quick maneuver because I dont trust it. I have comp front springs and Js out back. I am running a "heavy" valved set of 14" travel shocks on extended mounts. I never spent much time in it before I did all this so it has taken some getting used to. So that is my desire behind this. My wife has fallen in love with the thing (after cussing it for two years as it has been rebuilt bottom to top). I want to make it a bit "safer" on the road.
My thoughts on placement------
It is so open to where you want to put it if you weren't married to the bar. Of coarse in
@jcardona1 case, we are going to have to get a little bit creative or lucky as to where it will "work." It is one thing to throw up a bar with 5 holes in it and make one work, but what we ideally want is to get the math correct so if we have 5 holes the correct one is the one in the center. That way you can have three "settings" for different time of year or loaded or unloaded.... Whatever you see where I am going. I think you can get a bit further up toward the front of you truck and end up with a 15"ish arm and be at a amount of control or tune for the rocks. Like you were saying to get the back to work a bit more which will actually make your truck sit more level as it applied the correct amount at the correct places. I dont think we could make it a street racer up that far but it would be a more "antirock" offroad bar.
Edit to add link attachment: I dont see why you idea of mounting it on the link wouldnt work? You would want to have the arm on the SB to be parallel to you link though. This would give it a perpendicular force vector to your SB arm at all times. It may even a bit better just for that fact. It would be a much more linear pull instead of all the angles changing when the attachment is the axle. The only thing is the amount of force you would be subjecting the link to. At possibly the worst place to put it. Right in the center of your links length. You would definitely want to reinforce that section but it could be done nicely. With a saddle or cradle piece that was a pinch connection on the heim that connected the SB arm and the link.
As for the back..... I am wanting to keep it in front and as tight to axle as I can. ONLY because I am thinking next summer may be a rear tank and transverse mounted cantilever C/O setup.
Jason
