Anyone have luck with doing this?
Bozeman, MT
Howdy,
Ordering all my parts for the Mini-Truck PS conversion on my 40. I have a total take off PS assembly off of a 84 minitruck.
Has anyone successfully reused the high pressure line and mated it to the saginaw pump?
60 bucks is a pricey HP Hose, just thougth I would see if anyone was able to make a Toyota hose fit the Sag pump?
Is it a flare fitting on both ends?
Thanks in advance-
Rezarf <><
REZARF said:
Howdy,
Rezarf <><
I did reuse it. Bought a Mini-truck gearbox with the nipples and high pressure line attached. Return line was cut. I read that you needed an adapter, but I screwed mine right in and tightened it down and have had no issues.
Thanks for the replies. Just wanting to know if the hose can be fitted. Not really trying to decide which way to go anymore.
This is my DD first and a trail rider second.
I need FAST (read no fab) turn around time to stay on the road.
I like how I can get the Sag pump anywhere, for a fraction of the cost.
I will not go bigger than 35's as I just scrape as I enter into my garage.
Thanks for the replies, anyone know a hydraulic hose shop in or around Denver/Boulder?
Thanks!
Rezarf <><
Thanks!
Rezarf <><
Maggo recommended THE PARKER STORE in commerce city
Thanks!
Rezarf <><
Roger that - and good luck!
If you can also get the PS pump from the '84 Mini, you can buy a bracket from Lance at Iron Pig to mount the pump in the smog pump location on your 40.
Good Luck
Good Luck
x2 - you could keep it all Toy and not need special hoses...
Does anyone know where this kind of adapter could be found? Would this be a hydraulic type fitting? Just trying to think who would carry something like this.
Ken, did you kinda cross thread that thing to get it in there?
Thanks in advance...
Rezarf <><
