Anyone? - CLC Classifieds thread
I have a Dana 60 ARB locker for sale. Removed locker from my front axle due to seal housing leaking. I purchased a new ARB locker and that is the reason for selling it.
Model RD36 for 4.10 and lower gear (4.56, 4.88, 5.13, etc.,)
You'll need a seal housing kit, shim pack, and bulkhead fittings.
seal housing part 080701SP $97 list, shim pack part shk001, $13 list, bulkhead fitting part # 170111 $22 list.
Locker has not been abused and worked great.
Comes with with airline hose, switch, and everything that comes from ARB.
$400 I can deliver to SCC if needed. Shipping is extra.
I'll take it. @Bama4door will pick it up for me at the event. Need a deposit or anything?
That was great!...very funny!
Sounds like a plan. No deposit needed. Thanks.
Tried to send you a PM, but it won't let me. I was going to send you my number so we can get in contact at SCC for me to pick the ARB up for Johnny.
Just wanted to post a HUGE THANK YOU to @pmccraney for the stock roof rack. Thanks a million and i hope you love your front runner rack
We threw everything in the box that came off the truck. Hope you figure it out.
I installed it last night. Was super easy thanks to a thread I found here on mud. Slowly and slowly I'm piecing back together my 100. Basically the guy who sold it did the timing belt/water pump and belts. Then removed the roof rack, all the towing hitches and inner bumper parts, and wind deflector, and put junk wheel center caps in. Probably to install the good stuff onto his before he sold it I suppose. At least I can check off the roof rack now. Haha
If you want a Yakima setup that mounts to the stock rack @under_psi has a new one he just replaced with FrontRunner stuff.
I may need that for my ARB awning install. I've hit a few roadblocks trying to work the install on the stock rack. I've got U bolts fitted but running into issues with L brackets. I ordered the rhino rack awning mount to overcome the L brackets, but there may not be enough clearance space between u bolt and bolt into awning. The rhino rack slides into cross bars so the Yakima may be needed.
