The radiator is about 4" higher than the rest of the cooling system, so the incline is not needed, but can help. Remember Matt, the truck has Propylene Glycol antifreeze so do not add water. Use Sierra or Evans coolant full strength only.
A pics of the rear of the radiator such that I can see the "details"?
Let me know how your heat issue turns out.
So Matt got this thing over here bright and early this am. So far we did the burp method and no air in system as far as we can tell. So for the hoses. The hose on the lower heater core side coming from the bottom of the radiator is cold and the outlet is luke warm. Both upper and lower hoses are warm/ hot to touch. So... still air in system, restricted heater core or?? Any help is appreciated. We will be trying to button all this up today so any help is appreciated.
CliNt
Clint,
What is the temp of the engine when its fully warmed up?
Allthough I've not asked before what tye of GM V-8 are we talking about and do you know the year model of the engine and what it came out of? I think you need to find a pickup that has the same type of engine setup and look at the heater hose routing.
I'm wondering if the heater hose plumbing is somehow screwed up as it routes to the heater core and out, and then to the radiator?
On my 92 GM pickup with 350 TBI, the heater hose runs from the rear of the intake to the heater core and then from the heater core direct to the radiator.
I don't know if you guys have a vortec 5.7 or 454 setup or what... but basically the coolant will run from the engine at some point to the heater core and then return to the engine or to the radiator. Different year 350's and bigblocks have coolant fittings at different locations on the intake and then some have ones on the water pump and the radiator. Like I said its important to check out a vehicle
that has an engine setup similar to what you guys have.
Is the heater hose hot that runs to the heater control valve....are you running the totyota heater control valve that's mounted to the firewall?
I think it would be helpful to take some pics of the heater hose layout and post them to this thread.
What year and size is the engine?
What is the temp of the engine when fully warmed up?
If no pics, then descirbe the full heater hose routing from engine to heater core and back.
Lets see some pics of the heater hoses routing and plumbing. We may be just stabing in the dark, where a pic may show the problem.
