I have not been able to find the rear window gasket (center) and have been told it is NLA.
Here are a few that i thought of.
-windshield vent flap
-bib light wire to housing boot
-turn signal rubber that goes between fender and turn signal
-rubber oval that goes on the lower part of the fire wall ribs. Wiring harness runs through it on drivers side and positive cable runs through it on pass side
-rubber wedge,boot that goes between the chrome shift stick and the black linkage rod on steering column for a 3 on the tree shifting
-rubber piece that is under the wing window on a FJ45 LV. it goes between the door and the window frame
View attachment 1247686 View attachment 1247685 View attachment 1247684 Hi Dan, I just thought about this little gem. OEM part number: 17848-60030
It's the rubber gasket that goes on top of the OEM single barrel SD40 and the D40 carburetor, Then the air cleaner on top of that. I would need at least 5 or 10. I would think that this is a rubber part that every SD40 or D40 single carburetor owner would need. It's been NLA for a long while.
Thanks,
Mark
Thanks,
Mark
DanI received 3 kits Monday, 2-45 & 1-40. Of course they are not complete but they are something I can work through. The quality looks great!
The wings I got are for '75 and newer. They said it was a mistake and many of the parts that are supposed to be in pairs came alone but so far everything looks great. The under windshield rubber fits very well but that is all I have been able to test so far.
If anyone needs the newer wings give me a call, the first is free if you test them for fit right away. I have no newer doors to try them on. I also have the door complete package for a '75 and newer if someone wants to try those for me, hopefully the same person...
For the rear fixed cab slider I would need an example to have it made. Anyone have one in bad shape that is good for measurements?
I am making good progress on these and I hope to have the complete early kits also very soon.
For those of you wanting the FJ55 kits I am afraid I would need everything for ezamples, I sold my 55 a few years ago. Or if someone local has one I can buy cheap?
For the carb spacer I would need a perfect one, it could be old and no longer flexable, even cracked. Anyone have one to sell me?
Well since your thread reads "ANY", how about SWB fixed cab - split window rubber?
I have samples that could be had........
