dustin said:I thought that the traction bar tilts up under load, and not down? Or does it also try to pull downward?
-Dustin
Poser said:had the mounting points on that cross member not been concentrated in the single area, but rather, distributed out more in a larger area over the tubular cross member, through gusseting that it would have required far more force to remove the mounts from the cross member.
I notice that you have a 79, did you have any clearance issues with your gas tank? If you have a few more pics it would be appreciated.John Smith said:I used that exact BTF bracket when I made mine. I used heims on the axle mount side.
rabid said:Looks very stout. I like the design.
Really, though.......Miller High Life Light? Really?
If Miller is the champagne of beers, is that the sparkling cider of beers?
Thanks
Felix said:John runs a Toybox, and due to the longer drivetrain, he had to replace the stock tank with a smaller one. I'm not sure if he put a fuel cell in the bed or a smaller tank underneath, but the stock one is gone.
bandy rooster said:i'd like to see where that crossmember mounts on both side on johns...
