Another traction bar design
Minneapolis, MN, US
Well, I had a bunch of guys over to help me put together a traction bar this past weekend. I think it came out great - it seems extremely stout. It was originally based on the JK Customs design, but we made some modifications as we went. I'm pretty confident in these guys' abilities - they're a lot more knowledgable than myself. The only problem is I won't be able to test it until the 40 is done. Specs: The axle brackets are 3/8" plate, the bar is I believe 2"x1.5" - 3/16" thick, the heim is a 3/4", and the tube for the sleeves and the heim bracket is 1.5"x3/16" (might be thicker). I think that's all correct - I had to make a lot of trips to the parts store as we went so some of it may have changed. I have a template for the axle brackets if anyone would like the measurements too.
Looks very stout. I like the design.
Really, though.......Miller High Life Light? Really?
If Miller is the champagne of beers, is that the sparkling cider of beers?
+1
:flipoff2:
Franky40 said:
That looks very well built, but I think if you are trying to eliminate spring wrap you will be dissapointed. From my experience the majority of spring wrap is produced in the front half of the spring and a top mounted bar does not help with that.
Location of the bar in that design makes almost no difference, it will eliminate spring wrap.. That is until either the Xmember dies or the bar bends right at the front axle mount.
Franky, if that bar only had one mount to the axle then you would have a point. the mount would be able to piviot on the axle. Because there are two mounting points and the bracket is welded to the axle, spring wrap will be eliminated...
I would have used thicker material on the square tube..
Soul_Man said:
Hey, I didn't bring that, but free beer is free beer!
I am a little concerned about the thickness of the square tube as well, but for what I'll be doing it should hold up. If I start getting crazy down the line I'll rebuild it with thicker tube and sleeve the crossmember, but that won't happen for a while.
I would like the template for the axle brackets if you don't mind (just shoot me a pm or something). I think it looks good. Did you use any type of bushings and if so what kind and if not what kind would you recommend. Also how would you go about sleeving that crossmember
I dig that shackle. Rebuilding my broken track bar is on the to-do list this next month. I will be copying you there for sure.
I too am concerned with the thickness of that bar. I busted mine in two just doing a burn out. The forces down there are pretty impressive. Maybe you can add a long gusset the whole length of the bar?
cheers-
Dustin
Tim-
Spread the load out more on the crossmember tube, and you should be fine...
Triangle gussets from each mounting ear, above the bolt, going out 3" should work well....I would also tie the two mounting ears together with a piece across the top, and secure that to the tube also....
Good luck!
-Steve
Poser said:
Tim-
Good luck!
-Steve
Are you saying that he should put the gussets on one each side of the ears on the rear axle, running outboard toward the wheels about 3" thus distributing the weight more on the rear axle?. Just wondering because I'm about to be building one myself.
I take it the pivoting, shackle-like setup on the front crossmember should be left to remain to be able to move for and aft, and one should just reinforce the crossmember itself here and not alter the actual design at the crossmember?
No.....
The cross member tube and axle tube are not the same.
Poser said:
Tim-
Good luck!
-Steve
I've been planning a very similar design myself, just waiting to get some cruiser time to work on it. I had planned on using the existing xmember as well, so I'd like a little more clarification, too...
Is this what you were suggesting?
If so, those gussets will add strength side to side & I guess it will spread the force from a point source somewhat, but (other than that) don't really give additional support against the mainly vertical forces induced by accel/decel., right?
Any thoughts on this?
Thanks. -Ed
Thanks. -Ed
Wrong.
In the picture posted by Troll, you can see where the hangers were tore from the cross member. I do not have any first hand knowledge or experience with the reason why Troll’s set up failed, however, I do know, that had the mounting points on that cross member not been concentrated in the single area, but rather, distributed out more in a larger area over the tubular cross member, through gusseting that it would have required far more force to remove the mounts from the cross member.
:beer:
