Ken,
Well, I agree and disagree with you at the same time. I read that thread awhile ago and understand what you are saying. I know that a snorkel helps keep the heat down, working somewhat as a cold air intake, as you are pulling ambient air from the outside (rather than from the hot engine compartment area). However, when you feel your intake on a hot day, it's hot (no empirical evidence/numbers to back this up), and therefore, it has to affect performance. If this weren't true, intercoolers wouldn't exist.
Now I know you tow your Jayco popup with S/C. Have you towed that on a hot day over Eisenhower/Vail? If so, how was your performance (speed, temp, etc. I think I remember you saying that you had to turn off the A/C?)
Bottom line, I want an intercooler. They're, well, cool... especially on a motor that runs really hot.
P.S. (Minor thread hijack) Have you seen these hitches:
Lock N' Roll Trailer Hitches
Definitely going to go this route when I buy an off road pop-up (leaning towards the Starcraft 10RT) this spring.
Never said an intercooler wouldn't be better, just disagree that the SC loses most of its effective advantage on a hot day. I have a SC and I know that to be a false statement.
It will make the cooling system run hoter due to more stuff in the way for airflow. The temp increase in my cooling system is unrelated to SC performance and the air fuel mixture process. Two seperate systems.
I have an aux fan now and don't need to sut off the AC going up the mtn passes on a hot day any more.
