ginericfj80 said:and you get the cool pssst! sound when you turn them off.
Ya, but with factories, nobody can tell when you lock. You can be macho and say you did the obstacle open.
ShottsUZJ100 said:Ya, but with factories, nobody can tell when you lock. You can be macho and say you did the obstacle open.![]()
KliersLC said:OEM,
ARB's are notorious for problems-air lines, compressor, oil leaks etc. I'll take anything toyota builds over most comparable items
Buy both if you can afford it!mason said:If you were in the market again for an 80, and found TWO 80s, both very close to the same year, mileage, and condition, but one has ARBs installed and the other has OEM lockers, which one would you choose?
--Eddie
reffug said:So you think its cool to lie about your driving prowess???![]()
Who would have thought it Shottz.![]()
ShottsUZJ100 said:The opposite is true FUG.No lying is necessary. I luv going up and over obstacles OPEN in the TRAC-100 while the 80's are locking R or F&R.
OK, back to task FUG!
NorCalDoug said:careful...
some of us have been on the trail with you...
cruiserdan said:That applies to twisting the RH shaft in an E-locker equipped vehicle. The splines on the RH axle are longer in order to accomodate the dog clutch sleeve. If the splines twist between the sleeve and the end of the axle shaft it is impossible to pull the RH shaft without cutting something up to gain access. I believe that in some cases the fork and/or sleeve or shaft has to be torched to get it apart.
sleeoffroad said:Depends on what tire size and what you are going to do with the truck. Hardcore 37" tires I would take the ARB's given everything else is the same. Search for thread on twisted splines on rear axle.
sleeoffroad said:Thought I should post it 4 times to make it clear![]()
mason said:Judging by the people who gave a definite nod to one versus the other, it looks like ARBs won out by 9 to 4 (C-Dan gave a nod to both, depending on the tire size). I didn't know the opinions would be that skewed, but it does give me a good starting point. Thanks, all.
--Eddie
