manual or auto .. IIRC 75 - 80 mph are more close to 3K rpm in my case .. and IMOP 3K it's my top comfy rpm range for my 1HD-T ..
Part of that is me backing off the skinny pedal as the EGT's start to climb up into a range I'm not comfortable with. However, the benefits of the larger tires outweigh the occasional painful climb up a large grade. Goes with the territory.
Also, looking at this setup 1hdt cable
I know it RHD, so the accelerator goes to CC box then CC cable goes to throttle lever, so there is only one cable controlling the throotle.
Hey New80. On a RHD, HDJ81 there is only the one cable coming from the accelerator pedal to the CC, then one running over the top of the engine to a cam system, then down to the pump.
Of course.
Would you mind holding my 200 yard target for me?
I don't have the shakes too bad at the moment.......![]()
Would you recommend going with the 1hz for a daily driver with low pressure turbo?The 80/diesel combination was never officially sold in Canada either. A bunch of JDM vehicles have surfaced there but the powerplant is not offically supported. That can slow the repair process significantly.
The only real drawback is availability of replacement parts locating people who know how to work on them.
A cool swap for a hobby vehicle but not appropriate for a one-car owner in my opinion. Nothing like having your only set of wheels laid up for several weeks waiting for parts from the other side of the world.
In your opinion would a 1hz with turbo be a better daily driver engine due to the readily available parts?
