Angles - Shims - 3" lift
England
Guess who......!!
with my ongoing UJ/diff rattle resonance I have been doing a lot of reading - when I did the lift I also installed the suggested shims - please see pix - but looking at the angle of the rear UJ it looks like there might be too much shim.......?? or are my eyes playing tricks?
Once again thanks you for all your assistance - its like being all alone here in the UK without your help!
Dan
The caster angle should be measured, then an appropriate shim used to make up the difference. It is important to install it in the correct orientation. Agree with it *looking too steep; but looks are deceiving; best to measure*... Where there is concern about the angle of the Ubolt in relation to the plate, longer Ubolts can be used, with washers under the "low" side of the plate to square out the bolt. The only other thing I know about shims, is that the aluminium shims can compress and deform over time and use. Georg @orangefj45 has a source for steel shims which will not deflect, and are also weldable... HTH
I am curious about the orientation of that spring shackle... My understanding of an anti-inversion shackle is that the center pin should be INBOARD, not OUTBOARD, but I am not familiar with that particular shackle, and am not certain that it IS wrong... just voicing my ponderance thereof...
I agree. You are destroying the pinion bearing. Take the shims out, measure the caster and deside do you need any. I think those are too much anyway.
FYI on my 4 inch lift I installed 4 degree shims in front and rear but when I checked the pinyon angles I ended up totally removing shims on rear axle and kept the shims to correct the castor on front. Also, DO NOT use aluminum shims anywhere, they smash down and move around and you can’t keep them torqued down. Been there done that.
