Anderson Plug Jumper Cables
Stuck between a rock and a hard place
Thanks to NLXTACY for planting the seed in my head to get this done at some time. For some reason the original thread was closed.
https://forum.ih8mud.com/80-series-tech/234463-how-worlds-most-expensive-jumper-cables.html
My setup is definitely much less expensive and simple, but in the end I am very happy with the results.
1. Three feet of marine-grade 2GA wire directly connected to Neg on the battery, and three feet to my cut-off switch for the Winch. BlueSea 3/8" eyelets, soldered, and sealed with waterproof self-sealing shrink tube
2. Anderson SB175 plugs - one for the 2GA on the vehicle-side, and one for 4GA on the cable side.
3. Cut off and soldered on the Anderson connector to a set of 4GA cables that I have had for at least 10 years.
4. Installed the vehicle-side plug to one of the captive nuts used originally for the AC Dryer (since relocated). High up, and behind the Slee Shortbus, so well protected.
5. Installed a dust-cover vehicle side.
6. Installed a handle on the cables to make it easier to engage, and remove.
I have likely no more than $40 in the whole setup since I already had the cables, and most of the tools, and have already thought about making a hard-wired battery tender plug.
:cheers:
Steve
cyclosteve-albums-dual-batteries-picture22767-jumper-cables-anderson-plug-conversion.jpg
I have had mine through 4 truck. So much easier to use..
Snake, where did you get "2-Gauge welding cable and 1000amp clamps" I need to upgrade mine. They have taken a beating over the years.
:cheers:
Steve
[/IMG]
Steve
Nice setup. I have a liberal amount of dielectric grease in my connectors.
Cheers
Stu
Cable, connectors, heatshrink and snakeskin all came from a local electronics surplus store (SkycraftSurplus)
1000amp clamps came from FleaBay
I purchased some of the Anderson bits locally, but also some from Scrubbercity on eBay (definitely less expensive, and everything in stock).
Stu, thanks for the tip on the di-electric grease, as I have a tube in the tool box.
:cheers:
Steve
Thanks for the info Snake. NP Steve.
I used my this morning...
Silly question, you guys are running a relay high up in the engine bay right? So those connectors on the bumper are not live?
Correct :)
My solenoid is right behind the driver's side battery and has two main leads...
One lead goes to the front winch and the other goes to a rear distribution block that splits to the rear winch and rear mounted Anderson connector, so neither winch nor the connector sees power until the switch is flipped :cool:
If you read my thread I have a solenoid and switch to turn it off and on
Yup, I sure did man.. thanks for the good write-up. I was just asking everyone else generally.:beer:
