Hello John,
Too bad. But 30+ year old bolts are likely to break.
However, it is not something that happens only to old rigs. Back in 2001, a supervisor and me were driving back to our base camp, after a field job, in a brand new Toyota truck (a Hilux, I think,) eight or nine months old at the time. Some 60 miles from our destination, we heard the same sounds you did, and the truck came to a sudden halt. Broken driveshaft bolts at the flange, shaft jammed into the road dirt.
We tried to call the dispatcher (no cell phone on that area back then) but we were in a "dark" spot and the radio was useless. So we decided to take out the shaft. It took a while to tear it down. Then we shifted the transfer to H4 and went on.
Back in base camp, we notified maintenance. "Another of these trucks with this problem," they said, "thankfully you guys did not call in for a mechanic." As if we had not tried...
It turned out that this particular truck and two "siblings," bought at the same time, had defective bolts and joints, which broke when you least expected it; replacement parts were just as fragile. That production batch was defective, and we found out the hard way. Eventually good parts came in.
This is not a reason to lose confidence in your Cruiser, which was built tough, and built to be repaired. In time you will correct everything previous owners repaired poorly or not at all. Give the old lady a chance.
My two cents.
JuanJ
My two cents.
JuanJ
). I took one quick snap, and forgot to take more later as I was planning.
I'll have to take a look at some true OEM ones to know for sure. Any way that you cut it now that I have a p/n for the OEM ones ( thanks amaurer
The shop owner has a 1HD-T powered 80 and he said that I have the H151 5 spd transmission, exactly like the one behind his 1HD-T. I looked it over and didn't see any markings that indiucates otherwise so unless you guys can point me to where marking are I'm going to declare this mystery solved.
