Build An HJ61 followed me home to Texas
All sorted :)
Where do you have the plating done? Looks great!
It's a place called Aerostar about 5 minutes from my house. I wish I could find another place because I used to be very cheap and now they have a minimum charge of $127 and anything other than bolts is another $127 minimum.
How about a little update. Injectors back from the injection shop on Friday. Took the block, crank, cam, cam bearings, and pistons to the machine shop yesterday. 1mm oversize pistons with alfin steel inserts. Polishing the crank and cam journals and checking balance of the pistons. Installing cam bearings.
While that's being done I'm going to try to get ahead of the game a bit and finish everything else I have my hands on.
Flushed the oil cooler and reinstalled in the housing with all new seals gaskets and refinished hardware.
Also started clear powder coating all the lines. The zinc finish looks nice as is and the heat does make it darker but the clear powder will really keep them looking slick for a long time.
I'm powder coating the lines for my engine as well so plenty to do.
Cleaned up the harmonic balancer and got it painted with rust bullet along with the rebuilt injectors. At this point it's a waiting game until I get the block back from the machine shop or a couple of pieces for the cylinder head to get it to the machine shop. I doubt the head will be a hold up. Also still waiting on the center main bearing from toyota. It has no eta and has been close to a month since I ordered it. Not looking good.
Goodness gracious Roma you do amazing work.
This is my own thread and I didn't even get a notification!
That oil cooler is sublimely beautiful. I need to clean up the HJ61 to make it worthy of your work.
Got the block back from the machine shop yesterday. Bored 1mm, polished the crank and camshaft journals, installed cam bearings, balanced the pistons.
I got the crank and cam soaked down in wd40, bagged, and stashed it in the house out of the humidity until I'm ready for it.
