Ask me, the split case is a better choice. I've worked on both, plenty of NP and NV transfer cases and their Toyota counterparts.
The first thing you need to figure it is where the noise is coming from. Are you sure it's the tcase? Could it be the rear diff? Have you checked to see if the pinion stake nut has come loose?!
If it were me, I'd jack up the truck and run it, then use a stethoscope to see where the noise is coming from.
Don't live with a "whine"!!! Figure out where it's coming from.
Then do something about it.
Before it's too late!![]()
well that's a friggen bummer!
lemme know what you find out. i have plenty of spare parts and rebuild kits on hand.
hth
georg
bummer man. Add a crawl box while its out.![]()
At least it happened during testing before you got out somewhere remote.
It must have been a good bit warn to start. I'm interested to see what failed though.
CONGRATS........ How many miles are on the case?
Take a very close look at the idler shaft, idler shaft bearings and main shaft bearing races. If you find any pitting, rebuild. I'd consider at the very least putting a new idler shaft in there.
Hth
Georg
I'd replace the idler with 150k miles on it since that's the one part in a split case that "wears out".
The bearings usually hold up very well.
Hth
Georg
the oil slinger is there for a reason. i would'nt put a case together without it. if the idler bearings are bad, then you might as well order a complete rebuild kit. by the time you pay for the dilfer shaft, bearings, washers and all the gaskets you're just about paying for a full kit anyways.
i have the kits in stock. might have a spare slinger as well.
hth
georg @ valley hybrids
What job does the Oil Slinger do?
Slings Oil ?
School me.
This is where I put my scan gauge...
