ALTERNATOR!!!
las vegas
So my alternator finally went again and I’m looking to possible get a bigger one for the rig because of potential led bars I’m going to install and 12000 pound winch .... any suggestions on a good one ?!?
Many say the 80 amp OEM is more than enough. Possibly so.
Me? I LOVE my photoman kit with my 150 amp Sequoia alternator. Especially when running my winch.
It’s not tho because when i last tan this set up with a new battery everything would flash once in a while or you could tell was struggling
Then you have other electrical issues that need to be addressed.
The alternator is not supplying winch power, the battery is. The alternator is going to be doing its best to keep the battery topped off during winching, but that's it. No alternator out there is going to supply the amount of current a laden winch can draw.
That is a misleading statement. The alternator is supplying current to the vehicle electrical system which the winch is one of many devices that consume that output. The OEM alternator just can not provide 100% of the total requirement of the winch, more so at low RPM. With the motor running both the battery and alternator combine to supply the needs of the winch. Having a higher output alternator means that a higher percentage of the total requirement can come from the alternator and the battery will be depleted at a slower rate. At some point the ability to run the winch is not limited by supplied energy but the ability to dissipate the generated heat. Higher alternator output can also potentially recharge a battery faster depending on other draws in the system, battery chemistries and thermal factors.
All that said, going back to original post, an addition of a LED lightbar is in itself not a reason to require a higher output alternator.
When you really need that big power to winch your way across the mall parking lot don’t piss around. Do like I do, I can winch from Macy’s to Red Robin with no issues getting my lunch order in on time. I am certain that I need BIG power and this badboy never disappoints. Why mess around?
1922550
Just add a throttle lock to your current setup for winching. As for your electrical issue, have you used a multimeter to measure your alternator output to the battery yet?
(sigh) Yes, you are correct. An M12K will draw around 300 amps at full load, so the 120 amp alternator will do more than a 90 amp alternator, until the alternator goes into thermal overload due to a long duty cycle. Then the battery is the only source of power.
In short, the OEM unit is more than sufficient for the majority of applications, and the OP has some electrical issues he needs to get sorted.
