Alternator Help Please
Tommy Shumpert
Spring/Woodlands Texas
im stressing out right now!.....
Son called me said 40 wouldn’t turn over. Battery dead. Battery is year old. Jumped it started right up.
Drove it home about 5 miles. Turned it off. Tried to restart. Dead.
So just figured alternator. I had a spare one from a 78. So swapped it out. Except the plug was different.
I didn’t pay attention to the letters on the alternator, I just wired bottom to bottom, side to side wires.
Jumped it started right up. Saw a puff of smoke and turned it right off.
As you can see in pick it fried a few wires.
Look in pic and you can see the letters are swapped.
The old one had E & F hooked up
New one has E & F except swapped.
So basically I hooked up the wires flippn backwards.
As you can see it fried some wires coming out of voltage regulator.
Am I screwed?
Did it fry voltage regulator?
If I flip wires on alternator and fix fried wires should I try and restart?
Or should I get regulator first.
Please help
Regardless, those wires must be fixed, and tested before you put them back in service.
I’m sooooooo mad
I’m sure of that.
As far as the VR, once you clean up the wiring and are ready to start it, put a multi meter on the battery and watch the voltage, should be pushing something like 14.8 VDC if the VR is doing it’s job right.
@Solace in Solitude does this ring a bell?
No, but it brings back a nightmare.
DISCONNECT THE BATTERY and leave it disconnected, until you are sure it’s all fixed.
When I hooked up my battery backwards, the magic smoke appeared.
I melted the 10ga WL wire and the 10ga W wire, from the alternator to the ammeter and beyond, to the fusebox, along with the fusible link.
My VR and Alternator weren’t damaged, but the melted 10ga wires, in the main harness, melted other wires’ insulation, in many places.
Mark (@Coolerman) helped me out by building another pair of 10ga WL and W wires.
I had to pull the main harness, unwrap it and inspect every inch of every wire, taping any bare wires with electrical tape. Then rewrap the harness and rehang it, with the new 10ga wires inside.
Everything worked great, but it was a lot of work.
DO NOT merely try fixes, you’ll just chance burning your harness and your 40 to the ground.
See if your fusible link is still good and Contact @Coolerman and beg him to help.
He can help you figure it all out and can sell you whatever wires, wrap, fusible link, etc. that you might need.
The good news... You’re gonna learn a lot about your 40’s electrical system.
Good luck.
EDIT: Hopefully, you will be luckier than I was. Your obviously melted wires look to be WG.
F would be for field wiring. This would normally have a varying voltage on it that is controlled by the voltage regulator. If the full battery voltage was applied to this wire with the engine running, then the alternator would have been pumping out maximum voltage and current. Possibly.
Great.....
Ok first off, where is the fusable link?
Hi Tommy ,
just remember one important thing , your a smart dude and a good person , u CAN fix this Correctly ,
with the Right OEM parts in short order ........
ok, So here we go ..............
- i am almost certain this is the correct OEM TOYOTA NOS voltage regulator u NEED , please go over my comparison photos carefully and see if
im right , if im Not i have a few other options , its hard to tell from your photo's where each color coded tracer stripe wire is in relation to
each connector bay layout , but there ARC Welded together Melted so u may need to double verify with your own eyes after the sun
comes up
- the only detail of your chain of events that's unclear to me is witch Alternator was bad and you removed & witch one was going to be the
New good working replacement ? the Green Plug F E N or the white Plug E F N ?
- either way , i have u covered on ALL the OEM connector housings & terminals your Gonna Need both Device side & Harness side , all use
the same Solid Brass .250 series Terminals
- YES , u fried the Voltage Regulator
- I have the Unique Green Plug F E N Harness side connector housing , please see photos
- i shot u a PM with my shops contact information & hours for saturday & sunday , after u look over that regulator , comparison u can give
me a shout if u have any technical questions , i will try to help u in any way i can
matt
Matt, thank you so much for the advice/help.
In my haste last night I purchased two from cruiser corps. Ya never know....
Voltage Regulator - OEM
Is this the correct one?
The replacement alternator I used was the one with the green connection. It can with the engine when I purchased it a while back.
I had also purchased a OEM wiring harness a while back off eBay for when I did my frameoff resto.
So I stole some OEM connectors off that.
Also, the PO put in a painless wiring harness. another reason I purchased the harness.
Probably will be purchasing another, after pulling this one out I bought it was pretty cut up.
Maybe you can point me in the right direction for that..
Back to the problem.
I stripped all the wire down from alternator to the VR, and up to the firewall.
The main meltdown happened in the area. Really from VR down about 18” or so.
I didn’t see anything behind firewall
Stole the wire from the harness I purchased and popped the VR off firewall replaced the wires coming out of it.
Plugged battery in, tested a few lights, blinkers, brakes, etc... all good.
Stated it up and checked all wires under hoop, under dash, etc...
Everything seems all good.
Will still replace VR when it comes in.
I do think I want to purchase an alternator sooner than later. Ya never know. It is a daily driver.
PM me alternator info please.
Eeewwwwwwww....
Matt, thank you so much for the advice/help. no problem
Is this the correct one? it does appear to match what is currently installed on your truck , and got meltdown'd
The replacement alternator I used was the one with the green connection. It can with the engine when I purchased it a while back. OK
So I stole some OEM connectors off that. thief .......:poof:
Maybe you can point me in the right direction for that.. ok
I didn’t see anything behind firewall good
Stole the wire from the harness I purchased and popped the VR off firewall replaced the wires coming out of it. please elaborate how u replaced the wires coming out of the voltage regulator ?
Will still replace VR when it comes in. u need to for sure
I do think I want to purchase an alternator sooner than later. Ya never know. It is a daily driver. did u perform a overall Charging System
Check with a digital multi-meter , to see what your alternator output Volts were at base Idle , then it like 2000-2500 RPM's briefly
as outlined in the FSM starting on page 9-5 ?
u also need to check your alternator with a OHM meter to see if its Fried or not
also , check ALL your glass tube fuses in your fuse box , they can look good but be burned behind the metal cap inside and fool u
please see the attached FSM pages for instructions on how to do your Charging System Check with the Volt meter & the Alternator
check with a OHM meter ...........
PM me alternator info please. ok
Eeewwwwwwww....
i knew u could do it ! Eeewwwwwwww is right :)
just a few more verification steps to go
My only concern besides your pending answer about the replacement the current meltdown voltage regulator wires coming out ,
that is making me Nervous..............:eek:
is when something like this happens , a MAJOR short to ground arc-weld meltdown , something has to give ? like a fusable link , or the
voltage regulator itself , or alternator internal electrical component of some kind
and besides your wire harness itself , we have Not found that something yet , and that's still a UN-Known that most likley exists
somewhere ?
Great Info Matt!! Helped out tremendously.
You asked about the wires on the VR. I replaced the 3 wires that are soldered and running to the connector. :).
Everything checked out ok.
I will have my new VR in today. It's 40amp. Is there anything I should know before I hook the new one up? its not going to blow up on me is it?? lol. not funny actually.
Hopefully since I turned it off right away that helped out on the destruction.
This happens more often than it should. Why they changed the positions of the FEN terminals over the years is unknown but it has caused a lot of harness meltdowns over the years. Fortunately it will only affect the wires between the regulator and the alternator and the fuse block but since this has a non-OEM harness, the fuse box wire may not be affected.
F = Field The regulator controls the field current (about 2-4 amps) which controls the alternator output.
E= GROUND!!!
N = Not used
By swapping those wires, you basically grounded the field terminal wire (White/Green). This created a dead short from ground, up through the White/Green field wire, to the regulator, through the regulator power resistor and finally through the sense wire (White/Red early or Black/Yellow later) going to the fuse block. That's why all three wires melted.
On the FJ40, including your 1975, that wire is fused at 15 amps. Don't know if the Painless harness fuses that or not but since it fried everything it must not be...
FYI the fusible link does not protect anything besides the main 10ga charge wires!!! Everything else is protected by the fuse box fuses.
