Well my gremlins still are getting me. After my stock alt died early last year I upgraded to a one wire GM alt. Then went with a dual battery setup with an isolator. This is when my problems began. The alt wouldn't charge the batteries. I ended up taking it back to the alt shop and they rebuilt it again. A month later I went on a wheeling trip and needed to use the winch and found out real quick it wasn't charging either battery suffeciently. So I ran the two optimas in parallel and ditched the isolater. Now one month later the alt is not charging. It's only putting out like 12.4 -13 volts. I've only have one wire comming from the alt going to the batteries. How could I be screwing up something?
This pic is before I took out the isolator but gives you an idea of where I'm comming from. I have trouble shot this crap so long that my head hurts. And I consider myself pretty good when it comes to electronics.
Bad ground. I just never thought it would be that. I had tried everything else. So I have run a ground from the alt the the ground on the frame. Works perfect. Thank you. No more battery problems and I can use my isolator now.
