I just finished the front axle job on my 93. Before the work, it tracked true and drove straight on the road. The steering wheel was cocked slightly to the right (clockwise). After doing the work, it pulls fairly strong to the right, and the steering wheel is nearly a quarter turn to the right.
I did not disconnect the tie rod ends on either side to do the work.
Is it common to need aligning after the axle job? I've read that the toe is really the only thing that can be adjusted on the alignment. I don't know much about alignment other than what I've read since this came about. Could the toe be changed during the axle job, and if so would that cause the problems I'm having? Or would it be more likely caused by bearings, brakes or some other part?
I've read through some threads about alignment, and I'm reading a few more. I'm going to check it out tomorrow if I get a chance, but wanted to know if I needed to be checking some others things as well.
Thanks
Thanks
