Alarm no chirpy...
Williston, ND
Recently (about 4 months ago) I about a lx450. The previous owner said that he never used the alarm because it was "touchy."
Turns out he was right. After reading the manual I learned that the key fob that locks the door...must be the same one to unlock it (or the alarm goes off). Pretty ridiculous....especially if you are not the only one in the family who drives it.
Anyway, it has never "chirped" when the alarm was set.i figured the speaker was blown...I replaced the speaker and still nothing.
I recently hit the "arm" button by mistake while I was exited the vehicle and the door was open....low and behold, I heard a steady tone from my speaker.
My question is...where do I start to look for the reason it does not chirp when the door is closed?? It locks Nd flashes the lights, but no tones. I k ow this sounds minor, but with the short range of the remote (need to to grey wire modd) and no tone...I have left the car unlocked more times than I would like to admit.
Thanks in advance! If u can solve this, u r a genius.
Mine chirps half the time and then silent the other half. I prefer silent.
Remove the piezo buzzer and it won't chirp at all. It's usually in the engine bay on the driver side corner, underneath the brake booster area. Typically it's a little red or black plastic cased piezo buzzer with 2 wires going to it
Not to hijack your thread but I have a somewhat related question.
If I unlock my Lexus using the key fob, all is well but if I use the key in the door lock the alarm goes crazy. Is this normal and does the system not recognize that I am using the correct key?
Thanks,
In some newer vehicles the system is smart enough to recognize the key. In the 80 series, not so much. You need to use the remote
Oh believe me I learned that lesson...... :)
Thanks,
That is how it works.....strange....
I have replaced piezo already
There is a way to turn the chirp off by how you program the alarm. Do you know which alarm system your truck is equipped with? Most are the RS3000/3200. Whats your remote look like?
Curious in a solution as well. Mine is a 97 w/ the RS3000. It didn't come with the key fobs but it did have some other aftermarket junk wired in.
I yanked it all out and sourced the correct fobs, programmed them and it locks/unlocks fine but the piezo never worked. I figured it had something to do with the other junk the PO had wired in and never bothered to trace the problem.
FWIW the RS3000 manual states the if you engage the alarm with the fob it must be disabled with the fob.
baktasht,
Thank you for this. I have a set of instructions, but not like this. I'll give it a shot when I get home tonight.
KK
Everything functioned as described but no chirp. I'll have to dig more into the electricals. Maybe cut the piezo and put a meter on the connections.
Not a top priority but just one of those things.
Helpful information/resource regardless.
Thx.
Thx.
What happens if your door is open and you hit the "arm" button??
Good question. Didn't think to check that. Answer...
Not a thing.
