Build AK HJ-75
Throttle cable pass through finished, still need to weld on nuts
Here is one example of why you need the lhd version of this spot welded on part on the firewall, aside from being part of the mounting points for the steering wheel column. The clutch pedal mount has two bolts that get bolted up to this needed part. I guess if I can’t find this needed part I can try and fab up something.
Just curious why you went to the effort to put it there? To keep oil warm too?
Cheers
That's where the factory cold climate model had the block heater. Didn't think about warming the oil, probably wouldn't warm the oil too much though.
That booster was what Charles had put in the truck, I think it was from a 80 series? I still have the brake booster from the BJ70 donor but hasn’t been used in over 10 yrs
You are going through all of this work on the conversion: I'd get a new booster and master at the same time. Refresh everything and get rid of old parts. There is a market for the old stuff too.
So that piece you’re in need of for the steering column. I’m trying to figure out what it is.
Is it just the piece that goes under the column to bolt it to the support bracket which is fastened
to the round pipe?
What did you prep for the POR-15? Wire wheel and a metal prepper?
I found the stuff only stuck to a patina. What were you going to top coat with?
I'm in the same boat here soon when i rip the flat deck off my 79
These are the tools I used to prep for the POR15
