grant5127 said:Anyone have a better idea on air cleaners for webers?? other than the box K&N or the adapter and stock over the valve cover style??
coiled40gary said:Oh, yah, the above adapter required the weber adapter that came with the carb for the stock aircleaner.
Another option...
I was looking for a larger rectangular filter to put in the K&N box because the airflow I calculated with the short box air cleaner provided was quite a bit less than the designed airflow for this carb, and the designed airflow of the DGAS38 is just what the calculated 100% efficiant 2F would draw at about 3000 RPMs. The 2F is not even close to 100% efficiant, so this carb should be fitted just about right for our needs (for the purists out there, of cource the stock carb is designed to be exactly what you need). I could easily find larger filters that fit in well, but I could not find much by way of longer clips that hold the box together with the taller filters. While doing that research, I discovered that K&N actually designed an air cleaner specifically for this weber carb, though none of the people who sell the weber for LCs offer this aircleaner.
The K&N part number is 56-9290.
I know this is an old agument and there are K&N fans out there that will tell you there is no problem with K&Ns, but I'm not convinced. But I did learn from the quad guys in Arizona, who see LOTS of dust, and even some water with their very exposed aircleaners, that that Outerwear placed over the K&N does eliminate the dust problem, and keeps water out of the carb too. So I would not run a K&N filter without this type of cover. K&N sells the same type of cover, and calls it their Dry Pre-Charger. The one they offer, as you will see in the picture is not a great fit, but with a single wire-tie, and caring more for funtionality than astetics, works just fine.
The K&N number for this is RF-1034DR (the last letter stands for the color red)
I got mine throught AJUSA on the internet:
air cleaner: $57.43
dry pre-charger: $29.32
Hope this helped,
gary
P.S. Yes, the carb is mounted backwards. You will notice the nice gentle curves of the throttle cable, and all the adjustments, even the removal bolts are lots easier to get to with this orientation.
