If you like the ride no need to do anything. But keep in mind. The lower the Mpa at starting point (unloaded). The less work the AHC has to do. Which, helps extend life of shock seal and globes. Carry to much weight, reduces life.
As you know. Toyota AHC Mpa spec, is unload. Your OM will also give some guidance on what maximum load for vehicle. You should expect higher Mpa loaded. Which is fine.
That said. You can benefit with lowering pressure, unloaded. You already are running front, below spec of 6.9Mpa. Lowering rear Mpa a bit more, will help balance front to rear.
Since you've King AHC rear coils. Unlike with OEM coils, spacer on coils, you may get some lift in rear. I'd start with 10mm space. See how much they, reduces rear Mpa. Unloaded you may see ~5.8Mpa. Alternately, you can do a sensor lowering. Lower rear on to King coils, so coils carry more weight. Just make sure you keep 3/4" rake.
Bottom line. The lower pressure, the better. Balance that with ride feel to your liking.
