Couple of weekends ago I installed a new single DIN head unit (Clarion CZ500) with a single DIN pocket purchased from Crutchfield. This head unit has been sitting in my garage waiting to be installed for close to two years now. I finally do and of course I must have ordered an open box item because the plug with pig tales is missing.
This ends up costing me another $30 from the local stereo shop, what are you going to do! Everything else goes smooth, I solder the two pig tales together the pocket fits on the stock bracket along with the head unit and I don't even need to trim the dash surround. It connects to my iPhone either through the USB plug or Bluetooth, hands free head set works perfect.
Feeling good, I get it all buttoned up and take it for a spin. Switch to radio and my favorite station doesn't work, nor the second fav, I finally find a couple of stations I like and they are good and bad with ever turn I take through the neighborhood. I think I forgot to hook the antenna wire up high in the dash when I put it back together so figure that must be the issue and park the rig. Two weeks later today I tear back into the dash and find that I did in fact clip the antenna wire high and tight like stock. I even brought out my stock double DIN and plugged the amp back in and the stations come in like a champ!
So now as I am putting the Clarion HU back in I notice it's better signal just before I get it pushed all the way back or if I put my hand under the unit and reach back behind it the signal gets really good.
So in my head there are only two options, either to cut the two ends off the antenna wires; Female plug from pig tale harness & Male plug from antenna mast and solder them together. Or try to find an antenna booster for this very issue?
So now as I am putting the Clarion HU back in I notice it's better signal just before I get it pushed all the way back or if I put my hand under the unit and reach back behind it the signal gets really good. So in my head there are only two options, either to cut the two ends off the antenna wires; Female plug from pig tale harness & Male plug from antenna mast and solder them together. Or try to find an antenna booster for this very issue?
