The temp there is usually higher that at the tstat housing since it has travelled through the engine and absorbed the heat by that point, at the tstat housing it has just been cooled by the radiator.
you installed it in the block, i wonder if there is much difference in temp between there and near your T-stat? might have to get another temp gauge and see.
Wonder if the sender is in a coolant passage, or an oil galley.
LoneRanger said:mine is in a coolant passage. I installed it in the coolant drain port.
dubsb said:What are your temperature readings at the drain port ? Since I was incorrect I might be running a bit warm.
I mounted an Auto Meter electric gauge on my 22RE in the place of the OEM sending unit. I mounted it in a A-pillar gauge pod from this guy:
Truck Pillars
My engine runs around 205 degrees whether the AC is on, cold day, hot day, whatever. I asked a Toyota Master Mechanic he says it's fine. It's nice to have an actual gauge that works. Oh and I added a Auto Meter oil pressure gauge too. I had to get an adapter for that...
Truck Pillars
Did you have to pull the dashboard to route all the cables for that?
