What are people doing these days for tie down anchors? The oem ones help but I feel like a few more points would help. Any bolt in garbage i can buy to save some time? @NLXTACY ???
Neat. These?I made small brackets that attach to the rear of the front seat mounts where they bolt into the body, when I have one of the rear seats pulled I mount some tie downs that I scavenged out of various gm products at the junkyard. I also added those nice gm tie downs on where the third row seat belts bolted in. I don't have any pics, but the gm tie downs are triangular in shape and fold flat on themselves.
Those are cool too and would work well for the rear seat bolts id imagineL-track is what I use on my drawers.
I also designed some of these with a 7/16" hole with 90 and 120 degree bends but never actually made more than prototypes.
go buy some climbing anchors.
Pretty cheap, and there are a few different shapes available. My buddy used them to install car seat tie downs
There a ton of under 4 dollar stainless steel climbing anchors that have a force rating of up to 5600lbf (22KN).
Fixe Hardware SS Hanger - 10mm | Bolts & Hangers | BackcountryGear.com
However, keep in mind they will only be as strong as the surface they are attached too.
Neat. These?![]()
Problem with climbing anchor is those 3 dots they put on them to bite into rocks. They actually make things slippery on metal so we really need contact surface that's completely flat. You can always grind them down but definitely a hassle.
Double check the threads when you use those as anchor points. I seem to remember something about federal rules for a SAE size thread for one or both of those. It might be a newer regulation.
Also, some vehicles have rust around the seat anchors in the 3rd row, check your sheet metal as well
Seat belt mount bolts are 7/16" x 20, the only std bolts on the rig.
