ABS wheel speed sensor
Corvallis OR
I broke one of my wheel speed sensors when I was tearing the axle down. I am planning on getting a new one from a wrecking yard. Can anyone tell me about compatibility? Does it matter if it is from the left or right, front or back? Are all the years that had ABS compatible?
Thanks!
So I finally got my 80 back together. I couldn't find an ABS sensor in a wrecking yard so I glued the broken sensor back together. I rebuilt the front end and used chomoly birfs and my glued sensor. Now the ABS light is on. Where do I start?
I had the same issue and had to replace the entire speed sensor harness. In my search I ended up with 2 of them so I have an extra one. It is used, if you are interested in it PM me.
I want to keep the ABS. Any other suggestions on what to do? Do I really need to replace the whole harness?
