ABS Sensor wire mushed options?
colorado front range north Lat: 40:23:57N (40.399
Website
www.rm-mi.net
Hey
I did not find an answer to what I am trying to decipher on my 94. Last winter in Colorado we had the spring blizzard and during that i had gotten some frozen chunks o snow wedged up the left front wheel area.
it mangled the two wires for ABS that run along the frame right where it re-drirects to go up ... i have a pic on my phone i can post here... but the quick question is...
can i check the resistence onthe wire to see if the mangleing by snow is the issue and i just need to replace the front left wire or do i have to buy a whole freekin unit to replace ... ie, can not just splice in new wire.
thanks
You should be able to check both resistance and continuity. If it's a broken wire I don't see why you couldn't splice it together and weatherseal it really well. Be a hell of a lot cheaper than a new front ABS harness.
I munched mine a few months ago when I pulled a boulder up into my wheel well. The ABS light came on and I haven't bothered to call Dan about a new one yet. I pulled the ABS fuse and stashed it. One of these days I may pony up for new wires. I broke both lines in 2-3 places where they run along the control arm.
I believe they are insulated, so you can't just splice them and walk away. You have to re- insulate them after you repair. I trashed mine pretty good and after inspecting the damage I decided it would be a real PITA to fix mine. I traced it around and found that there is a plug behind the wheel well under the driver door and then the wires run along the control arm and go to 2 other plugs, one at the DS knuckle and the other on the back side of the axle on the DS. I believe if I purchased a new one it would be this entire section with the plugs.
The ABS cable is very stretchy. The wire inside will snap but the outside will look normal.
You can feel the cable for the broken spot (if it is obviously damaged outside, you have an easier time locating the offending area :) )
cut open the rubber sheath and solder the wire together. Test for good continuity, liquid electrical tape and/or electrical tape and some shrink wrap. You are good to go.
If you need to replace actual wire, get the same gauge wire to mimic the resistance- see if that works. .10 is a lot better than $$$ for new oem cable!
The harness is spendy (~400+) so fixing is worth some effort. Also, you could look into used parts a la Cruiserparts.net.
thanks everyone. a local beer drinking riding buddy stopped by yesterday and as he is a professional electronics/auto guy.. he iterated what you all are saying too. so... cool i will splice some in and reset the ABS and let you all know results...
he also described how ABS works by a magnetic sensor that reads frequency of a toothed wheel on the tire/system and compares rotational speed of each tire that way then if one is not rotating (skidding) it pulses that hydrolic brake .... cool.
thanks again.....( will check the used parts source too! )
Rock on
