About to do something really stupid…
Tacoma, WA
I’m going to weld my Rig’d Rambleswing to the receiver hitch. I need it to perform just slightly better so I can mount two Jerry cans, propane, and a diesel heater. It’s slightly overweight and it can get a bit wobbly after long moderate+ trails. The carrier itself is solid but the receiver will slip a bit after prolonged stress.
I’m all-in on this minimalist bumper setup. Still need to chop the resonator, then it’ll be perfect.
Why don't you just get one of the anti-rattler things instead? Don't you want to be able to remove it from your hitch?
How about welding some attachment points to the rack toward the ends and using a couple big ratchet straps to the vehicle frame to solidly stabilize the rack.
I wouldn't recommend welding the hitch.
As you're going down the fabrication route, a better approach might be welding or fabricating a brace nearest the pivot, tying that to the underside of the E&E skids. Perhaps better as a bolt in bracket so that it can be removed. Some metal, taps, and bolts would make for a more rigid support, than welding or adding more beef at the hitch.
steel wedges hammered in beside the hitch, ive done this, i hate rattles
I use this anti rattle hitch device and it is solid as a tank. I’m in the process of getting a couple more, one for our other cruiser and a couple as spares. If you think this could be a possible solution for you I’m more than happy to send you one to try out.
I dunno man, aside from weight savings, this has all the headaches of a purpose built swing out and one insane compromise that requires you to weld it to the hitch. You'd be better off with a dissent or something.
—Just an opinion from a guy on the internet
Just to be a contrarian and support stupid ideas, you don't have to make a full circumferential weld around the hitch. A couple intermittent beads along the side should do the trick and they can be removed with a die grinder/angle grinder fairly easily. Just remember to remove the leads to your battery to protect the electronics in the vehicle.
This is exactly what I was thinking - better than a tack but not a full 360 bead either. A grinder and some sand paper can get it back to original condition if it’s ever needed.
Some people have commitment issues. 😜
Got me curious, looked up price of the swing…wow!
Just through another option out there, you could bed it in epoxy :cool:
Exactly what I’ve been looking for! PM incoming.
