Aaarrrghhh
Littleton, Colorado
We still have a problem with the knuckle arms :mad:. We got brand new wheels with 3.5in back spacing on them, And they still get really close to the wheel. the only thing that rubs is the little rubber boot on the tierod end. it barley rubs on the wheel and hits the weights. thats with the 1/4in spacers :eek:
heres the wheels, http://www.discounttire.com/dtcs/fi...0126&rc=CODINT&tpc=UNIQ42&tp=Truck&st=Classic
what should I do? im definetly not goin to get some more wheels :mad: .should I switch the knuckle arms and cut and weld the tierods? :confused: :confused:
PLEASE!! help me
My TRE boots are long gone. Is that the only problem?
The vintage is self contained, in that it uses nothing from the factory heating system, it's all removed. It contains heat, air, and defrost in a single unit. Your factory heater bits are up for ebay after installation. It does have the compressor and bracket, of course, along with the condenser and drier. I will say the piece that mounts to where the old fan blower box is is s***. It's a crappy plastic piece that cracks very easily. If you go vintage, throw that crap in the trash after having it duplicated at a sheet metal shop. While the air is cold, you need to insulate a 40 with window tint, and under floor (mat) insulation if you want to be comfortable over about 85 degrees.
Scratch that...meant to go to the vintage air thread...WTF?
O.K. i guess i am going to ask another question in this thread how do you measure back spacing because mine are suppose to have a 4 inch back spacing . they just rub the boot .using after market poly tre dust boots doesn't rub . i am using no spacers . if i use weights they get knocked off too . i just get the stick on weights . and balance from the inside . they will hit caliper if put in the wrong spot . but otherwise work . mine are suppose to be 15x10 with 4 inch back spacing . how exactly do you measure the back spacing ??? if yours are that close mine can't be 4 inch back spacing
I have to think that the disc equipped cruisers are more different than just discs because my Rims are 4.25" backspacing and I have almost an inch clearance of the TRE.
take the rim off, lay it face down, put something like a ruler across the wheel and measure from there down to the back face (where it sits up against the hub). that measurement is your backspacing.
buy some rims from summit, I had the same problem with this and my rims hitting the D ring style rims. The summit racing rims have more of an angle and won't hit steering components, etc. Summit will make them in any custom bspacing you want, they are really cheap too, come in white or bare metal.
Noah
they are perfect . with 1/4 spacers and 3.5 bs mine run the exact same. if the boot barely rubs rim and the tre would take off any weights you left on then thats just right.
This way you can hear and feel if the steering arms come loose at knuckle cause they rub on rim then ........
Performance wheel and tire on Sante Fe and and Oxford has a huge assortment of new and used RIM's. Rather than working something to fit a wrong style rim, you may want to trade them at Performance for a set of used RIMs. They have a lot and in good shape.
I have been running 1/4" spacers without trouble and Im not too close to the TRE, but I would hesitate to go much more with a regular spacer. It would seem to me that that would give the wheel more leverage on the studs and stress them. I saw pics on this forum of spacers that looked they were bolt on and beefy, don't know anything about them but I am sure others here do.
You can't return these wheels?
I agree with Ian that more spacer = more problems , I would run em as I ill say I've seen 3 rigs up close and personal that run that set up , like mine and yours , and all have 0 probs and even saved one guy cause he felt the tre dragging on rim and sure enough the knuckle studs were loose.
