I was looking at the compushift site last night. I seems that have it pretty much figured out in terms of the controller.I would call HGM Electronics in California. They make Compushift which is a stand alone TCU for all sorts of applications. Guy, one of the owners, is incredibly knowledgeable about all things transmissions and electronics. I was able to work extensively with him at one point to put an A750F behind a Cummins R2.8 tuned to 200hp/400ftlbs in an 80 series with the factory console but used a 100 series gated shifter. If you are looking at keeping a Toyota trans and the 80 Tcase then the A750F is a great option as the TCase bolts up and overall length is nearly the same as the 343. It even mounts the same as the 343 and requires no driveshaft changes. A750 is stronger and 11% more efficient on paper but you already have the 343's.
Between 442 and 343, I prefer the 343. I own both and the 343 at 366k miles seems in better shape than the 442 at 259k miles. I've have a turbo'd 1fz in front of the 343 and have yet to do a shift kit to help out. You would likely benefit from the transgo shift kit to hold more power if you stick with the 343.
I have a transgo kit on hand as it happens.
Mark...
