- Joined
- Sep 19, 2012
- Threads
- 55
- Messages
- 604
- Thread starter
- #21
I have a couple impact extensions. They are black. They really do cut back on the applied torque though. I believe I may have got mine loose with a 3/8 snap-on butterfly impact. I was surprised they were as easy as they were.
I thought maybe you had some extra EGR type tubing that mine didn't have. Is it just the A/C pipe lost in 3D perspective?
Sometimes you can come in through the fender (wheel off) to get to a bolt you may not be able reach otherwise. Takes a lot of extensions, and boy, when they let loose... Pow! ... and then you check, hoping it was the bolt that broke loose! Sometimes you win. Use 1/2" drive stuff to minimize the twist up.
I won't be able to work on the truck again until Saturday night/Sunday. So I have time to pick up an impact extension. I will try that. I'll just wear my motorcycle helmet so nothing smashes me in the face! I have been pleasantly surprised that most of the bolts/nuts have come off with little struggle, despite 20 years of Michigan driving.
I'm gonna take the front wheel off too, just to give myself more room.
and yeah, I'm pretty sure it's the AC pipe.
A few more quick ?s if you gentlemen please
1. My rear heater lines were corroded and the PO bypassed them. I'd like to remove them altogether. Does anybody have diagrams/pics of what can be pulled?
(edit: If this makes a difference, it looks like the exhaust is all original. The cats and corresponding studs are all pretty damn corroded. They are sealed and working fine, but I am worried that if I get into removing the cats to get to the heater lines, I'll open another $$$ can of worms)
2. Talking about removing the EGR stuff. What's involved in this? What can/should/shouldn't be removed? Pros/cons to removing the EGR stuff? Do I need blockoff plates? Anybody make them, or would I need to have them fabbed up?
I'm sure it's a common feeling, but I can't help but thinking that there has to be a way to clean this engine bay up and make things simpler. Anything that I can get away with removing would be a bonus, in my opinion.
Appreciate the help. I'm still green, but hoping to come out of this with a lot more knowledge!
