A few SOA/spring q's
Sacramento, CA
I am getting stuff set up to do a SOA set up, and part of this is cleaning up some older springs so I can put another main leaf into the pack that I am going to use and take a few out from the bottom of it. Question is, which leaf is the main leaf? When I take them apart, I get six leaves: 10 1/2", 18", 25", 32", 38", and the two leaves (military wrap, I think) at 46" eye to eye. So, which is it?
Also, when I do the spring over, I am planning on extending the wheel base a little bit. Which end is better?
Thanks for the help!
you can do both ends to extend you wheel base, what springs are you using?
i would extend the rear. its easier to relocate the rear shock mounts plus you don't have to deal with steering and the complications that follow it.
what do you mean by main leaf? and why does it matter? as long as the pack is put together right... explain a bit more ..
Stock springs
alright, I have got the four leaf packs underneath my 40 right now. I have got a couple more leaf packs that I have got that I am tearing down right now. I want to take the main leaf out of the packs on the side, cut it down a little bit, and put it into the packs that I have underneath my truck right now, after taking the two bottom leafs out of those packs. Hope that helps.
Trial and error is the only way to determine what leaves you need to use. It depends on the condition of the leaves, weight of your truck and accessories, how you've done the SOA and what final result you're after (low SOA, higher SOA, good ride, stiffer ride for loads, ???). The answers to all these questions and more make it so there is no "right" answer to your question IMHO.
Nick
