A Costly Slip
Gig Harbor, WA
Well, today was pretty icy and one small error in judgement led to a costly (I am guessing $100+) fix.
Does anyone have the part # for the power seat switch (oak) for the driver's side seat?
Long story short, I slipped while getting out of the LC today at work and luckily I did not get seriously hurt but the driver's seat got the brunt of it. The power seat switch cushioned my fall and as a result it was broken flush with the seat panel. I have a contusion on my right shoulder blade (luckily my uniform kept the switch from tearing through my shirt.
Glen
Glad your OK.
Might be able to replace that with one thats being parted out.
I'd call cruiserdan or your local delaer (if you get a discount) and see what the new one will run you. They will have the part number.
Romer,
Thanks for the quick reply. One of the first things I did when I got home was check the vehicles being parted out. Oddly enough most are the grey interior and the oak ones seems to be pretty stripped.
If I do not get a reply tonight I will call the local dealer and see what the number and price/availability would run. If there is no joy there I will contact Dan (because he seems to have a stockpile of cruiser parts).
The biggest pain (no pun intended) is the R/R of the switch. I looked through the FSM and it looks like I have to take apart a bunch of stuff just to get to the switch.
Glen
If you plan on recovering the seats in the future, might be a good time to do that unless the seat is in a bad position.
Alright you are scaring me --- I was just looking into how much it would be for the seat cushions and the covers (from Shane of course) but I might need to put that off until I return at the end of the year.
Currently I already have my "discretional money" alotted against a couple other pojects and for me to swing close to another 1K just before deploying will be next to impossible.
Keep the idea coming maybe you come up with an assiciated project that I have not yet. I am running a list of like items (heated seats, auxilary fuse box, OEM switches in the center console, new foam, new leather) that I can accomplish once the seats are out.
Glen
A new switch is about 150 bucks and the seat will need to be unbolted and tipped backwards to work on it. The lower seat cover will have to be partially removed and the switch bezel will have to come off. The bezel will almost certainly break in the process so you may want to get a new on ahead of time since you won't be able to reassemble without it.
Dan,
Are the switches interior color specific, meaning there is a part # for both Oak and Grey or is it just one switch (no matter what interior) and then a color specific bezel?
The reason I am asking is like Romer suggested there are vehicles being parted out that may have the switch but most are the grey interior. Actually there is a grey 96 that is very close so if it would work I could feasibly pick up the switch locally.
Do you have the part numbers for the switch and the bezel assembly?
Glen
I recently tried to order a new switch assembly and was told that they only come in black, but you can get them colored to match your interior. Ultimately I contacted cruiserparts.net and got a replacement. In my search I found that many of the same switch parts were used in other lexusi and could have gone that route too. If I recall correctly the sc300 and 400 have the correct parts.
Karl
FYI if you don't move your seat often, you can insert a small screw driver, etc into the holes and still move the settings. My wife tried breaking her kneecap on her old 80 and thats what we did until I found a replacement.
well, hope it'll work out easily for you.
If it can make you feel better, wait until your truck slips off a big rock and slams into another one on the side, now that's a costly slip.... :)
