A/C Panel Wonky after window tinting
Status
Not open for further replies.
Dissent
Questioning my life choices...
GOLD Star
Sweetwater, TN (SW of Knoxville)
Picked up my 97 LX450 from the tint shop yesterday and the A/C panel freaked out. Lit up across the middle (A/c, Auto, Recirc) an a relay clicked on an off a few times. It didn't do it again and the system worked fine going home n. this morning the panel is mostly not responding. The middle row won't respond at all, the top row and fan speed respond but the fan won't change speeds. The vent is bringing in outside air. The source buttons redirect properly.
It's not the fuse as the radio and cig lighter work fine. I think the panel got wet during the install. Shop says nothing happened (big surprise).
What's it take to replace this panel cost and parts wise?
Anyone seen this before????
Are any of the buttons stuck? (jammed in?) or feel sticky when pressed?
You could also try shooting some compressed air in around the buttons to see if any moisture escapes.
Nope, no buttons stuck. Dealer part is $434. Does anyone have one for sale? It has the Auto button in the middle for the LX model.
See if it can be disassembled, I'd take a look inside before spending that kind of money.
Loose connector in the dash?? Did they tint the top of the windshield or the front door windows?
Nothing removed from dashboard. They were doing the windshield strip. Found some water pooling around my CDL switch above the heater controls before the display on it freaked out yesterday. Not likely that a wire is loose, looks like a short. I found one on ebay for $137 and ordered it because I need it but still need to find the root cause. Looks like I'm screwed is the end result :(
I will bet the root cause is water inside the unit.
You should only consider yourself screwed for jumping the gun on buying a new one without first investigating the old one.
I'm at work and can't look at it until tonight. If there is water, it most likely shorted something out. I don't see it working last night, not working today, working again after the water is removed. It should have dried up overnight I would suspect. The weekend is introducing more delays. I'm screwed because its just sucky in general. I don't see a chance of it coming back but again, can't do much until tonight anyway. Jumping the gun is opening up options not being irresponsible.
Here's a "cool story bro" for ya:
Found one of the new Nintenbo DS whatevers. My 3yo daughter already had a DS, but this one was newer. It WAS bright pink but apparently some didn't like pink and colored it black with a marker. I took it home for my daughter for a backup. It worked great but looked like total s*** from being colored black with a marker.
Few days later I caught her washing it with soapy water in the sink. I had a good laugh and then taught her that "things with batteries don't like water." She wanted to keep it to pretend with. So it didn't get tossed.
Fast foward over a month and she is running to me telling me that the "ugly DS" works again.
Moral of the story: Stuff dries out and works again.
Lol. Thanks. Hoping for the best!
You might want to talk to the tint shop about damaging your AC panel. Some shops are quite liberal with the spray.
See above. I'll have to take him the damaged one on Monday. They were VERY liberal with the spray. Stained up my seat covers too. Those should wash up though.
Found the problem and I'm wicked pissed! The A/C Amplifier above the drivers pedal has standing water in it! I took it apart and found water I poured out along with corroded circuit board to ribbon cable and pins on the harness plug. This part is $650! Here's a pic. He must have gone nuts with the water given the rust in the metal plate under the steering wheel in 24 hours in Phoenix!
:eek:
please tell me that wasn't the Bell Glass guys
I cleaned everything that looked corroded or water damaged in the A/C Amplifier and the connectors then reassembled it. Plugged it aml back together and to my amazement, IT WORKS!!!
I recommend that anyone who owns an 80 Series with that amplifier above the gas pedal (LX450 and 40th Anniversary for sure) take a few minutes and pull it out, inspect it and clean the board to prevent any issues. It was such a pain in the rump to troubleshoot. The good thing is there isn't much in the actual heater controls to go wrong. It's mostly just button positions and lights. The amplifier is the real brain.
:bounce:
Now that I understand more about how it works, I see no need for a spare panel. I'll return it to the yard or sell it. Anyone need a panel?
Just wanted to close this thread out saying that the tint shopped called this morning and said all the right things. He even offered to reimburse me for my time. I told him that I appreciated that but it wasn't necessary as it gave me more bonding time with my 80! :D
He did offer to severely discount any tint in the future so that ended much better than I had anticipated. Good guys in the end! :cheers:
Status
