A/C issue
Michigan, USA
A/C has stopped working. If I go to climate control and hit the A/C button it goes on for about 4 seconds then switches back off. I have the temp settings on Lo. any advise?
Rent or buy a set of gauges, looks like low on refrigerant. Check your condenser for any oily moisture.
Have rust? If so there’s a common leak point where the rear AC lines go through the floor into the rear condenser.
It’s likely low on refrigerant, as suggested above. I had some success with a leak in my son’s Honda by using a recharge kit containing UV dye. With a recharge and a UV light I quickly found and fixed a leaking seal. It’s a crude method but got the AC working without getting dinged hundreds for dealer repair.
Thanks, hopefully the dye will be able be seen there
We have a saying that goes, "dye never lies". Unless it's your evaporator then you have to dig in.
I had the compressor clutch relay fail on my 2016 LC several years ago--see my posting entitled A/C Clutch Relay or something like that.
