Build 96 White Cloud
This is the paperwork from previous owner. He bought from original owner at 69k. And drove it 200k. There are receipts from everything imaginable. Even a brake light they took it to the shop. Auto house of Clovis in Cali. Anyone familiar with this shop?
Every oil change, etc… crazy. Engine was rebuilt at 255k, oil pump, pistons, rob bearings, mains, block was machined, gaskets. Etc.
Timing chain , rail was changed a year before.
Crazy. Only thing I don’t see is anything done to trans. 🤨🤷‍♂️
Great indicator of a well cared for rig. You did good.
I like it.
Looks good. What lift specs did you end up with?
I went with 3" Dobinson, front and rear sway bar ext., front caster brackets, rear pan hard brackets top and bottom. See how that works out and may get upper rear adjustable control arms.
Anyone ever used this setup? My exhaust is toast, muffler is done!
Looking for options.
TIA
I haven't tried one of these plug-and-play exhaust setups. I suppose that could be super convenient and save you some money, as long as it fits and isn't missing anything.
After I get my turbo installed, I'll be taking mine in to a local shop for a new system all the way back. I found him on Google and he just does them in his garage shop. Has hundreds of 5 star reviews, and his price was super reasonable. He makes the bends in his shop. Does a fantastic job - you can use pretty much any muffler you want. Maybe there is someone near you doing something similar?
Injector wiring question.
Can someone please verify the 3 wires coming out this location go to 3 5 6?
4 is up the harness.
Had to replace broken connectors and I didn’t label before ….😤
Hey bro. When you say “go to 3 5 6” do you mean go to cylinders 3, 5 and 6? I think that’s what you’re asking. I can check mine.
