I love you guys! 2.5 years of 4x4 Impotency Fixed!!!
Ok...I purchased my 97 FZJ80 w/factory lockers about 2.5 years ago from another MUDDER.. unfortunately when I bought it the lockers wouldn't engage.. Figured I'd have to tear the lockers apart and clean them up since all I got was the dreaded blinking locker lights.... Anyway, I came across this thread this past week and realized that there is a process to the friggin madness to engaging the lockers!
I've wheeled it, used 4LO and even engaged the CDL button(installed by PO) and could hear the CDL engage and the click in the kick panel... but I never realized there was a CDL light that was suppose to turn on, nor did I know the ABS was suppose to shut off and light up as well. Did some more
Anyway, I read this and the other posts that the lights have to turn on in order to engage them! I did the figure eight thing I pulled the CDL switch on the dash to check to make sure it was not loose and even climbed under the truck and pulled the connector from the CDL sensor to make sure it wasn't gummed up. Still after trying some wiggling of wires and trying to reach around to short the sensor it still didn't work....
Grrrr. Being the type that doesn't give up easily.. I said screw it and went looking for a wrench to pull the sensor.. I figured it it worked for Bearcat80... it might be the ticket.
Didn't have a 27mm wrench, I did however have a 1 1/8 wrench which fit perfectly and it turned right off... The little spring loaded thingy seemed to function fine, looked to be in good shape.. pushed it in and out about 30 or so times, did the paperclip shorting out thing at the same time, reinstalled it and hooked the connector back up. Got in the truck and started the engine....engaged 4LO and wait.....wait for it......wait....f.o.r......it......nothing! Damn. So I figured I'll just move the truck back down the driveway and park it..... as soon as I put it in drive, LO & Behold.... the LIGHTS CAME ON!!!! Both the CDL and the ABS light!!!!
Hallelujah!
(Bright heavenly light from the clouds open up and shining down on me)
I then engaged the lockers... both of them... sure enough the front engaged (NO BLINKING!!!) but the rear wouldn't engage.... so not to be outdone by a stubborn ornery LC... I took it to the street re-engaged the CDL,
CDL Light 'check',
ABS light 'check', and commenced to engage front and rear lockers, blink.... blink....blink..... PULL BACK AND SET THE HOOK... SOLID FRONT AND REAR LOCKERS!!! Drove it down the block (really slow) turned them off, turned it back on, off, on, off on....!!! HELL YEAH!!! SUCCESS MOFO!!!
Oh man... I was so happy!! my neighbors probably thought I was some crazy guy! Thinking I'm just learning to drive or something... cuz it was slow and the tires chirping and truck heaving like a kid on his first day trying to drive a stick shift!! Anyway sorry for the long winded post.. but I just want to thank all of you mudders before me that figured this out and kicked down the knowledge!!
Thanks again! If your ever in LA.. I'll buy you guys a beer!!
ScottyDog 'officially 3x locked!! WOO-HOO!!
