- Joined
- Apr 22, 2014
- Threads
- 2
- Messages
- 14
I've read as ma ny trans related posts as I can find and I'm still at a loss. I bought a 94 fzj that the front driveshaft had blown up on and knocked a hole in the case where the trans cooler came out. I bought a junkyard trans and put it in. First try after acceleration it would slip in drive. Put it in L or 2 and it was fine. Tried 4lo and locking center diff, same result. Adjusted the "kick down" cable fore and aft, it was better with it tighter, but still stalled to around 3k rpms. Called it a night and went to mess with it the next day, now I dont have L or 2, it doesnt even try ti creep forward, can mat it and its like its in neutral. Since I had the other trans there I took the solenoids out of it and reinstalled in my junkyard trans as well as cleaned out the screen (it was disgusting). No change. Fluid is filled correctly and doesn't smell burnt at all, it was replaced with the new trans but if it was slipping that bad I would think it would get a smell to it. Checked all harness connections and they're clean. No OD flash codes
