93 transmission question
Beaumont, texas
after getting up to temp I have noticed my transmission will sometimes not start out in first gear, even when I shift into L. I am changing the fluid tomorrow as a precaution, but is there anything else I should be aware of in the event that doesn't work? I read on previous posts that the electrical connection could be gummed up, and that the solenoids may need to be replaced. Should I be nervous that a rebuild/replacement may be in the near future?
Jump the Tt and E1 pins in the data port then turn the ignition on. Count the blinks of the OD OFF light
Example of blinks: . . . . . . (Pause) . . . (Long pause) . . . . . . (pause) . . . Is code 63. Does that make sense? If it just blinks continuously there are no codes
I had a similar issue with my 93 and it ended up being a solenoid. It was stuck open. Replaced it and it shifts great now.
My '94 sometimes does that, hasn't bugged me enough to troubleshoot it. Also sometimes when I shift it from Park to Drive it doesn't engage, put the shifter back into park and back into drive and it works fine. Been doing this since I bought it at 118k miles, 268k miles on it now. Fluid isn't burnt and no particles in the pan... One day I might fix it as I am sure it's a solenoid issue.
Try just dropping it into first, then through second and into Drive as you get moving, that gets mine going.
Best to fix it rather than limp it along. If you don't have an aftermarket belly pan skid plate its very easy to get to the solenoids. But before you do any of that you need to check for and read any transmission codes.
Download your FSM here: Downloadable Toyota FSM's
Download, save, print, archive, etc the 1994 FZJ80 FSM the A442 Tranny FSM and the A442 Tranny Supplemental FSM
The A442F is the transmission in your 93 and is what these manuals cover in depth. in the A442 Tranny Supplemental FSM On page AT-16 TROUBLESHOOTING begins, you can read through the chart and see if your problem is described but the more useful information (IMO) starts on the next page.
AT-17 & AT-18 detail how to pull your transmission codes. AT-19 has a chart with the codes and descriptions next to them.
Pull your codes and report back
It's Code 062, Solenoid #1. So, I guess my next question is the solenoid in the valve box? I found the solenoid online, but it came with three different part #'s 85420-60050, 85420-60030, & 85420-60060. Are they all the same?
Also found this here RTH - A442F shift solenoids - which is which?
"As you may know, the A442 is apparently the same thing as an AW450-43le, a truck transmission produced out of the union between Aisin-Warner. You can purchase solenoids that are listed for the AW450 for under $50 each at cobratransmission.com. ... Cobra is not the only place to find these but they are the cheapest I found.
Shift 1 and 2- D49422A
Lockup- D49425A
Timing- D49421A
(800)293-1848"​
to get to the solenoids you have to drain the trans fluid (measure what comes out so you can fill the exact same amount later, its usually about 7 liters). Then drop the trans oil pan skid plate, then the pan. You'll be looking at the solenoids at that point, it should look like this:
img_4099-jpg.1454590
Note the order as shown in the FSM here:
solenoid-repair-jpg.1659957
Here is a thread with all of the part numbers
https://forum.ih8mud.com/threads/fzj80-a442f-transmission-solenoids-from-aw450-43le.988260/
When you go to reassemble you can use Blue RTV to make a gasket just make sure both surfaces are clean (scrape and brush all of the old gasket off). Lay your bead of RTV on the pan, let it set for about 5-10 mins, then place the pan back on the transmission. Finger tighten the bolts DO NOT torque at this time. Wait one hour then torque per the spec, don't over torque, I think the spec is something way low like 12ft-lbs.
You can replace all 4 for less than $200. See this link for a cheaper source for solenoids. I installed these over a year ago and it fixed the same issue you’re having. Get some OEM gasket maker (FIPG) and the solenoids. That’s all you need. It can be done in a couple hours.
Where to buy transmission solenoids?
Dont forget the two, one gallon jugs of Dex/Merc ATF. And it is possible to do it that fast unless you have under armor / 100lb belly pan
Either OEM FIPG or "The Right Stuff" in black (not gray). Blue RTV does not like oil long term. The others can be operated in 15 minutes after applying.
Great info. That pic of the trans open helps a lot the trans fsm diagram was hard to relate. Thanks a lot, I will be tackling this, this weekend!
