92 Front Heater Core Pull
W. PA
Since I got my 92 last year, the front heater has always blown cold air, rear heat blows hot air when I ask it to.
I found the previous owner used stop lead instead of coolant and several of the hoses were plugged solid.
I have to pull the dash anyway and anticipate replacing the heater core. I realize they are discontinued, so sourcing helpful hints?
My '92 FSM seems to have nothing whatsoever about the heater core. Any helpful hints on pulling it?
Thanks!
Albert
Here is mine and it is leaking. I Can't seem to find a replacment. Later parts or third party parts don't have welded tubes .Have you found a solution? Need to get a part this week, i ahev the dash out.
I’m in the same boat. I just use the rear heater in the winter and with rear seats flipped up it keeps the heat up front. Bad thing is no heat for the defrosters. I’ve heard people doing a flush with CLR to get the circulation and heat back but I haven’t tried it yet. Definitely not pulling the dash apart...
I actually snatched up the last Toyota heater core for my '97 when Onur so kindly shared low inventory status many months ago.
I was only able to source one of the pipes that extends out as the other was already NLA at time of purchase. :( Hope I never have to deal with replacing it as I've seen the DIY thread. lmao
I replaced the heater core in my '95 a couple of years ago and happened to get one of the last heater cores also. From talking with Onur about the part it seemed like the pipes coming off the '97 version were not connected to the core like the earlier version is. I honestly have no clue if a '97 core is still available and if its even the same layout as the '92 but to me it seemed like I could have swapped in the '97 core into my '95. I would of just needed to buy one of the pipes that comes off the core.
My heater core on my '94 started leaking 3 weeks ago. I took it in to my mechanic and am having him fix it. My mechanic couldn't find a replacement heater core for my rig. He said the only one he saw for sale new was in Saudi Arabia. So we ended up sending my heater core to a shop to get repaired and rebuilt. As you know, replacing the heater core requires removing the WHOLE dash. It's costing me $1500 to get my heater core rebuilt and replaced. I thought I saw front heater cores for sale on Cruiserparts.
Here is a picture of what my rig looks like currently with the dash ripped apart.
