- Joined
- Jan 8, 2006
- Threads
- 265
- Messages
- 9,823
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
Oh crap Dan, I feel like I owe you money now!
Fantastic stuff!!!!
Fantastic stuff!!!!Follow along with the video below to see how to install our site as a web app on your home screen.
Fantastic stuff!!!!
It really makes what was a great truck, an oustanding truck. I loved my 22R-E...until I got the diesel in. In fact, the way I did the swap left it possible for me to undo the diesel wiring and put the 22R-E back in. I'm trying to sell that 22R-E because I realized that even if my engine dies on me, that I just won't be happy without a diesel in it. It's better on a trail (yes, that truck sees some trails--just not super nasty ones), it's better on a road, and it's better at a fuel pump.
-I don't believe the 3L head can be any better than the updated 2LT2/E head. If anything the swirl chambers might be smaller for a higher comp ratio. T3L is a lot more durable because it is NA and has much less heat to deal with. IMO getting rid of the EGR and adding an intercooler will make a bigger difference.
-did the LN130 come in a single battery setup like the small style starter suggest ?
). So far, so good. I've got room on the left to put in another battery, but like I said, the single Optima has worked very, very well for me so far.-did you get the built-in or external voltage regulator ?
-you had to make just one bracket, wow ! when I did the 2LT2 swap in my engineless hilux (originally 2L2) I had to redo the tranny and driveshaft mount, move the rear axle back, and seriously mod an oil pan. So much for a straight drop-in, bolt-on project
I'm guessing that having a half-cut really made the process simpler for me, as I had both driveshafts, the tranny crossmember, and everything else in the drivetrain (minus the rear axle). I pretty much replaced the original stuff with the diesel parts from the halfcut because they were lower mileage, but I may have saved myself some heartache by doing so.Alright, I think I get everything except the "bread trick" pilot bearing? What?![]()
See the attached pic. I want to say it was an IC alternator, but I might have it the other way around. Basically, it was the same as my stock wiring. The plugs were the same, and after tracing the wires (despite one color difference) I realized they were interchangeable. So I just plugged the diesel alternator into the original wiring harness (actually I extended the 3 wire harness to connect to the LH alternator). Hasn't hiccuped once.
This is an excellent write up.
Thanks.
And you even answeed some trans bolt pattern questions I had
This thread belongs in the FAQ!
could you measure the core height to see if its 2WD compatible ?
Thanks ! I need just the core height everything else is the same. I want to see if a stockish turbo rad exists that fits in a 2WD 3rd gen. I would like to use the turbo specific water outlet/thermostat housing, but then again I could just have my current rad. cap... capped. I just don't want to butcher it at this point because I will need it as-is in the LN130 that will remain NA either in a 2L2 or a 3L fashionSo, I'll see if I can remember to measure it when I get home next (feel free to remind me if I've forgotten). I *should* get to go home around June 23 or so. You just need the height of the core?
Unfortunately the PS pump support is integral with the engine mount and the alt. mount. I have a RHD alt in the shop and *IIRC* it doesn't fit the LHD lower support at all.The RH PS pump would be on an LHD 2LT-E truck only right? I wasn't quite willing to risk taking the chance that it would be compatible with a PS pump from a 2L, so I made due with what I had.
How much did you spend on this swap? My 22re is dead! and I was thinking about doing the 3.4 5vz-fe swap, but if this swap is as easy as you say besides the wiring I might do it instead. Do you have any #'s on the new motor as in hp and torque? My rig will be strictly off road so fuel milage will not be an issue. It just means I will be able to go farther on the trail. Let me know what you think.
