Time for a front axle rebuild if you haven't done it. Fluid exchange and bearing repack if you have.
Then a winch..... And a buddy cause that tree is always gonna be 5' outta reach. Murphy at his finest.
(And then the fine print which very well may not apply here but make sure you're on legal land. ROWs are off limits here and tow truck drivers call cops first and more importantly it feeds the folks trying to further limit our access. Rant off )
All good. ROW. Right of ways. Used to be totally acceptable and accessible spot to play but in more and more places now days owned and maintained by utilities and municipalities and generally no trespassing. Didn't mean to hijack with a PSA simply meant dont offer the environmental group any ammo against us is all. Glad you got out an everyone got a laugh
And my note about the axle was more about after sitting submerged in water for that long it may pay to drain diff fluid and check for water ingress to the knuckles/bearings before finding out in 6mos at 65mph somethings wrong
It's cool, I'd rather someone tell me than learn the hard way.
Would water creep into the front axle even if it's got a fresh rebuild?
If your axles are underwater long enough, it is possible that water may have migrated in. Watch for your diff breather as well, a lot of guys here have extended breather lines.
From personal experience I agree that a fluid change and bearing repack is a good idea. You will probably want to check the rear axle as well. I just got done with some very EXPENSIVE repairs to my rear axle that looks like was caused by water intrusion (likely before I purchased the truck last year). It's definitely worth your time to make sure all axle internals are as they should be.
Damn. I'll be staying away from big puddles for a while after this.
Thank you, the knowledge is much appreciated.
Big puddles isn't necessarily the issue, it's the time the truck spends with the axles submerged that is the problem. If they've been submerged for longer than say....10min (total guess) I'd say it's a good idea to check the fluid and grease.
Normal water crossings/puddle-jumping shouldn't cause much problem as long as you're not getting stuff for long periods.
Wow,didn't realize until this experience how aptly named this forum is. Currently in the driveway power washing all the mud off. So, what are we talking here, no driving until this is sorted out? Lower speed trips into town likely to cause damage? Avoid the highway?
I can repack the bearings and flush out the fluids this weekend. Rear axle was just as deep as the front, so I'll change out the fluid there too.
Differential locks are a must have for a guy who just has to know if he can do it. Welcome to mud.
I even got out and found a big stick to prod with. Water depth seemed fine,mud underneath questionable, but F it, I really wanted to see where this trail leads. I was 4' short of a solid landing, I was standing on it to take the stuck picture.
