cool thanks, I will definitely check it out, but I think I will be done by then.
What would you like to add or change if you can?
- I'm making the bottom frame out of 1.5" square tubing, rails are 1" square tube, I'm not making the light grill in front but it can be added later easily with removable mounts and at any size desired.
- I'm making the fuel can storage movable front and rear bc fuel cans over my head is not appealing, also thinking about putting a rod through the fuel can handles and put a lock on it.
- The front and back rails will also be removable to carry longer things like a kayak, or lumber including 4x8 plywood. The all the rails can come off to have a flat rack for whatever reasons.
- I will also add spare tire carrier in front and rear of the rack, it will slide to the left, right or center of the rack to make room for other gears or to balance out the weight if you are driving alone.
- The corners on the frame will be 45 degrees for a bit of aesthetic than the square box.
- Hi lift jack mounts, shovel mounts, hooks through out the frame for easy tie down.
