'88 FJ62 - Need frame rust and price check
NYC
Hi guys. I'm looking to hopefully buy my first 60 series -- something I've wanted since the 6th grade. She's out of state, a ways away from me so before I make a trip and/or ask a shop to do a PPI, I thought I'd ask for some expert opinions on the frame and price here. Thanks in advance!
The truck is an '88 with 231k miles on her chassis and 155k miles on a 3FE that was swapped in by TrollHole's Cruisers 2 years ago. A previous owner also swapped in an H55. Interior's fine and she's got some nice ad-ons (ARB front bumper, Warn winch, sliders, 4x4 labs read bumper, and a Sherpa rack). Seller says all she needs is maybe a new transfer case seal.
To my untrained eye, the frame rust is acceptable. I see the rear frame rails have surface rust with some scaling, rear shackle mounts look good with no deformation, and the crossmember also only has surface rust with edges still well defined. The exhaust hanger is more corroded but that's easily replaced.
Am I reading this right and what would be an honest price for the truck? Seller is asking mid 20s which maybe a few thousand high because I don't really know the quality of the engine or transmission swaps.
Link to more photos: '88 FJ62 Charlotte · Saturday, Apr 18 📸 - https://photos.app.goo.gl/kSaW2EfckLtPqntZ7 And again, I appreciate the advice and hope to join the club soon!
I'd like to see a photo of the crossmember the rear shocks are attached to. How is the body? Better be rust free for that price. I'd ask for more photos of the common rust areas and also of the engine bay. Conditions of fuel tank, fuel pump bracket and fuel lines are important to check IMO. The H55 is a big plus. For sure it'd be worth paying someone for an inspection if everything looks good. TrollHole's is a reputable shop.
Initial views look pretty good. You'll want to replace that spare though as someone cut corners and didn't replace all 5 tire which is fairly common. As others have said, a good PPI would be money well spent. I live in Harlem NYC/Kent CT and would not keep this truck in NYC unless you have a secure inside garage for all seasons, especially winter. Would add a GPS tracker and pull the coil wire if left for a while. As soon as the salt flies, I don't drive mine.
Good luck with the search and enjoy. These are great trucks.
Cheers, James
Frame looks ok to me. Body rust can always be an issue. I'm the original owner of an 88 with 155K miles and wouldn't sell mine for twice the price.
Take a close look at the inner frame rails near the front of the rear wheel arches. That tends to be where they rust through. Stick a finger into some of the frame openings: often the frame is full of packed dirt and sand, which traps moisture that causes the frame to rust from the inside out. Because the inner frame rails are thinner steel, they rust through first.
